方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
With stereoscopic particle image velocimetry (SPIV) we can measure all 3 components (3C) of the velocity in the plane of a laser light sheet. SPIV makes use of 2 cameras that view the laser light sheet from two different directions. In each measurement point in the plane of the light sheet, each camera measures the projection of the particle displacement perpendicular to its viewing direction, and the complete velocity vector can be reconstructed from these projections. First the 2C-vector fields from each camea must be mapped (dewarped) from the image planes onto the measurement plane of the light sheet and interpolated on a common grid. Then the displacement vectors from both cameras are combined to calculate (reconstruct) the 3 components of the particle displacement. The dewarping and reconstruction can in principle be based on the exact knowledge of the geometry of the setup, but most often they are based on a calibration procedure. The geometry of the setup is then derived from a set of calibration images from a grid placed in the measurement plane. A more extensive discussion of the dewarping, the reconstruction and the 3D-calibration procedure is given in (S1-S6).
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
