方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The wake behind a simpli¯ed model of a generic aircraft (the SWIM model) is measured in the Low Speed Low turbulence wind tunnel (LSL) at Delft University of Technology. Two measurement techniques have been used in order to qualitatively and quantitatively measure the wake, i.e. stereoscopic particle image velocimetry (Stereo PIV) and a 5 hole probe (5HP). Furthermore balance measurements have been carried out over a range of con¯gurations for later comparison purposes. The goal of the wake measurements is to give a comparison between the two measurement techniques. The 5HP measurements are processed using a windows based program called Pressure Field Visualisation. This program calculates vector ¯elds from the input pressure data and has several exporting options. The Stereo PIV measurements are correlated using DaVis 7.3 using a window size of 16 x 16 pixels with 50% overlap.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
