方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
In the context of tackling the ill-posed inverse problem of motion estimation from image sequences, we propose to introduce prior knowledge on ow regularity given by turbulence statistical models. Prior regularity is formalized using turbulence power laws describing statistically self-similar structure of motion increments across scales. The motion estimation method minimizes the error of an image observation model while constraining second order structure function to behave as a power law within a prescribed range. Thanks to a Bayesian modeling framework, the motion estimation method is able to jointly infer the most likely power law directly from image data. The method is assessed on velocity elds of 2D or quasi-2D ows. Estimation accuracy is rst evaluated on a synthetic image sequence of homogeneous and isotropic 2D turbulence. Results obtained with the approach based on physics of uids outperforms state-of-the-art. Then, the method analyzes atmospheric turbulence using a real meteorological image sequence. Selecting the most likely power law model enables the recovery of physical quantities which are of major interest for turbulence atmospheric characterization. In particular, from meteorological images we are able to estimate energy and enstrophy uxes of turbulent cascades, which are in agreement with previous in situ measurements.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
