方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The active control of laminar and turbulent flows with dynamic actuators is of great scientific and technological interest in nearly all fields of fluid mechanics. Today, most of the well established actuator concepts are based on pneumatic and micro-mechanic bases. However, owing to their limited dynamic range, their potential seems to be limited from the present point of view [1]. Recently it was successfully demonstrated that a boundary layer flow can be efficiently controlled by using an optical actuator concept, which allows non-intrusive excitation of the flow with nearly any pulse-width and repetition-rate by heating the surface of a model with a short-focused laser pulse [2]. The drawback of the proposed and examined method was the gradual ablation of the model surface. To avoid this problem the excitation was performed above the surface in this investigation [3]. By using the phased locked stereoscopic PIV and Schlieren technique the dynamic effect of the laser induced plasma on a boundary layer flow could be examined in detail. In this contribution the main results will be summarized and the perspective of this actuation method for fundamental and applied fluid mechanics will be outlined.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
