方案下载应用领域 | 食品/农产品 |
检测样本 | 其他饮料 |
检测项目 | 食品添加剂 |
参考标准 | DB33/T 703 食品和农产品中多种碱性工业染料的测定 液相色谱-串联质谱法 |
In Formula 1 racing, there is a strong motive for reducing component weight and thereby improving efficiency. This paper demonstrates the advantages Additive Manufacturing brings to the production of hydraulic components. The Direct Metal Laser Sintering (DMLS) production technique enables weight reductions to be attained by its geometric design freedom coupled with this material’s attributes. The use of EOS Titanium Ti64 material for hydraulic components has been assessed by a hydraulic soak test at 25 MPa and no significant losses or failure occurred. The benefits to the efficiency of hydraulic flow have been measured using Particle Image Velocimetry (PIV) and the use of DMLS manufactured geometry has improved flow characteristics by 250% over that of the currently used techniques of manufacturing channels and bores.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
