方案下载应用领域 | 交通 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Now-a-days, the stratified and direct injection spark ignition engines are becoming very popular because of their low fuel consumption and exhaust emissions. But, the challenges to them are the formation and control of the charge which is mainly dependent on the in-cylinder fluid flows. Today, an optical tool like particle image velocimetry (PIV) is extensively used for the in-cylinder fluid flow measurements. This paper deals with the experimental investigations of the in-cylinder fluid tumble flows in a motored internal combustion engine with a flat piston at different engine speeds during intake and compression strokes using PIV. The two-dimensional in-cylinder flow measurements and analysis of tumble flows have been carried out in the combustion space on a vertical plane at the cylinder axis. To analyze the fluid flows, ensemble average velocity vectors have been used. To characterize the tumble flow, tumble ratio has been estimated. From the results, it is found that the tumble ratio mainly varies with crank angle positions. At the end of compression stroke, maximum turbulent kinetic energy is more at higher engine speeds. Present study will be very useful in understanding the effect of engine speeds on the in-cylinder fluid tumble flows under real engine conditions.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
