方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
A flat plate boundary layer flow was generated at the open test section of the circuit type 1m- wind tunnel of the DLR, Gottingen, at a free stream velocity of U亣 = 7 m/s with zero pressure gradients. A transparent and smooth surface glass plate is utilized to provide optical access from its bottom and a good flow quality. The plate has an elliptic leading edge to prevent flow separation. Four tripping wires, one with 1.5 mm diameter and three with 1 mm diameter were positioned with 1 mm x-distance close to the surface at (Rex). . 290 along the whole span-wise elongation of the plate. This bypass transition of the flow results in the development of a turbulent boundary layer flow. In a box of about 34 x 18 x 35 mm3 in x-y and z-directions around (Rex). . 450 tracer particles has been illuminated by laser light pulses at 4 kHz with 21 mJ each in order to achieve PIV recordings without using the frame straddling method. The light source was a Nd:YAG laser from Lee Laser inc. Two highly reflective dielectric mirrors aligned in the x-y-direction are installed nearly parallel and close to the surface of the flat plate on opposite sides of the measurement region. The collimated laser beam undergoes multiple reflections between the two mirrors passing through the measurement volume approximately 15 times before exiting (see sketch left). This arrangement resulted in a light amplification with a factor ~5 with respect to a single pass system. The specific illumination arrangement has the advantage that all viewing directions collect scattered light both in forward and backward directions, which provided the level of light needed for imaging particles in the whole volume.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
