方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The spatial and temporal development of turbulent boundary layer flows is governed by the self-organization of coherent structures like hairpin-like or arch vortices and spanwise alternating wall bounded low- and highspeed streaks. For a detailed analysis of the topologies of the wall normal fluid exchange namely of the four quadrants of the instantaneous Reynolds stresses Q1,…,Q4 a 4D- measurement technique is desired. In this feasibility study the tomographic PIV technique (Elsinga et al. 2005) has been applied to time resolved PIV recordings. Four high speed CMOS cameras are imaging tracer particles which were illuminated in a volume inside a boundary layer flow at 4 kHz by using two high repetitive Nd:YAG pulse lasers. The instantaneously acquired single particle images of these cameras have been used for a three dimensional tomographic reconstruction of the light intensity distribution of the particle images in a volume of voxels (volume elements) virtually representing the measurement volume. Each of two subsequently acquired and reconstructed particle image distributions are cross-correlated in small interrogation volumes using iterative multi-grid schemes with volume-deformation in order to determine a time series of instantaneous 3D-3C velocity vector fields.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
