流化床化学链式反应的高温流体力学研究
2013/05/04   下载量: 6
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
In the present work the effect of temperature on the hydrodynamic behavior of fluidized beds is experimentally studied with modern non-invasive experimental techniques. In particular, the development of a high temperature endoscopic Particle Image Velocimetry (PIV) is presented. An experimental set up has been designed and constructed that allows the study of hydrodynamics up to temperatures of 1000 oC, typical temperatures encountered in chemical looping gasification processes. First the endoscopic PIV results have been validated at low temperatures with a cold flow setup. Subsequently the application of the new technique to high temperature fluidized beds is presented and the obtained results discussed.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 扑翼推进振动翼型的RANS数值模拟和流场测量结果的比较研究
文献贡献者
相关方案
当前位置: 欧兰科技 方案 流化床化学链式反应的高温流体力学研究
