破碎波夹气区速度场测量
2013/05/05   下载量: 4
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
Turbulence generated by wave breaking was investigated using a novel non-intrusive measurement technique called bubble image velocimetry (BIV). The violent velocity field in the highly aerated region of a broken wave was obtained using BIV. The mean velocity and turbulent intensity were obtained by ensemble averaging 20 repeated measurements. It was found that the maximum mean velocity reached 1.81C with C being the phase speed, occurred shortly after the first impingement. The maximum turbulence intensity, however, occurred at the second impingement induced by the first splash, reached 0.96C or 67% of the maximum mean velocity at that moment.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 分形扰流片的气动声学性能
文献贡献者
相关方案
当前位置: 欧兰科技 方案 破碎波夹气区速度场测量
