贻贝幼体对湍流的反应不因年龄和光线条件而改变
2013/06/01   下载量: 2
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
Larval responses to hydromechanical cues potentially have important effects on larval dispersal and settlement. This study examined the behavior of mussel larvae (Mytilus edulis) in laboratory-generated turbulence representative of nearshore currents. We video recorded the behavior of early- and late-stage veligers in a grid-stirred tank at five turbulence levels under light and dark conditions. Water velocities and kinetic energy dissipation rates were measured using particle image velocimetry and acoustic Doppler velocimetry. We characterized the vertical velocity distributions for sinking, hovering, and swimming modes in still water and calculated the average larval behavioral velocity in turbulence. In still water, young larvae had more positive (upward) velocities than old larvae, and both stages had more positive velocities in light than in dark. In turbulence, the mean larval vertical velocity varied from positive at low dissipation rates to negative at dissipation rates above a threshold of 8.3 ?1022 cm2 s23. At this threshold, the Kolmogorov length scale (h ?590mm) was two to three times the mean larval shell lengths (171?56mm), implying that turbulence is detectable even by larvae that are smaller than the smallest eddies. Responses to turbulence were unaffected by larval age or light conditions and contributed substantial behavioral variation. By sinking in strong turbulence, mussel larvae could increase their flux to the bed in energetic coastal flows, particularly over rough substrates like mussel beds. The response to turbulence by early-stage larvae will also affect their dispersal and may help larvae remain near coastal populations.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 壁面湍流边界层压力起伏的高速层析PIV(Tomo-PIV)和直接数值模拟(DNS)的比较研究
文献贡献者
相关方案
当前位置: 欧兰科技 方案 贻贝幼体对湍流的反应不因年龄和光线条件而改变
