方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
We performed an experimental study of large-scale wakes in a rotating shallow-water layer. Standard particle image velocimetry was used to measure the horizontal velocity field, while a laser-induced fluorescence technique was used to measure the geopotential deviation i.e., the interface deviation. According to these measurements, we were able to quantify the dynamics in a wide region of parameter space beyond the quasi-geostrophic regime. For obstacles larger than the deformation radius and with small Rossby numbers, a significant asymmetry occurs in the wake between cyclonic and anticyclonic vortices. These parameters correspond to a frontal geostrophic regime with the relative interface deviation being larger than 0.1–0.2. In this case, anticyclones remain coherent and circular, whereas cyclones tend to be elongated and distorted. More surprisingly, for some extreme cases, coherent cyclones do not emerge at all, and only an anticyclonic vortex street appears several diameters behind the obstacle. The transition from a quasi-geostrophic to a frontal geostrophic regime is characterized by a strong increase in the Strouhal number, which can reach a value up to 0.6. Hence, we found that a large-scale wake could differ strongly from the classical Karman street when the relative geopotential deviation becomes larger than the Rossby number.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
