方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
To apply Tomographic PIV to industrial flow, ex. flow around rain gutter, 50 mm volume thickness and 0.1 ppp particle density, at least, are necessary. In such experimental conditions, signal to ghost ratio of object images and accuracy of vectors are problems. To tackle these problems, influence of number of cameras, image pre-processing and vector post-processing to the accuracy of Tomographic PIV are experimentally investigated at different measurement volume thickness and particle densities. This investigation reveals that time-series minimum subtraction at each pixel without any spatial filter is suitable for image pre-processing for such conditions. Although this filter results in lower signal to ghost ratio, better vector field without less spurious vectors than a traditional one. This signal to ghost ratio is improved linearly by increasing the number of camera up to 8 and accuracy of velocity vectors also increasing up to 8 at any particle density and volume thickness conditions. This improvement by increasing the number of camera is experimentally proved as a first time. Obtained velocity vectors are filtered by spatial filter in physical domain and frequency domain to reduce measurement noise. Filtered velocity profile of thick volume measurable domain, 135 x 230 x 50 mm3 in air, is well coincident with previous experiments even in velocity fluctuation and Reynolds stress. To resolve turbulent fine scale vortex and large scale vortex simultaneously, more than 6-camera are needed for the case of 0.12 ppp particle density and 50 mm volume thickness. For the case of 0.45 ppp and 50 mm volume thickness with 8-camera has also enough accuracy to access velocity fluctuation and Reynolds stress. This paper achieves the large measurable domain, 160 x 220 x 80 mm3, at the particle density of 0.53 ppp.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
