方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Although acoustics consists in the propagation of an oscillatory disturbance of local pressure, particle velocity, density and temperature, sound measurement is often assimilated to pressure measurement. This is because for decades only pressure fluctuations were accessible and because their relation with the other oscillatory quantities is well known under linear acoustic approximation and in simple configurations. Such a correct description of the origins of sound has long been known from the theory of sound, but there is a bad habit of acousticians to use the descriptions of sound as acoustic pressure only. Meanwhile, a sound wave is a form of energy transport in the field and has the vectors features. Sound intensity (SI) as a vector variable inseparably couples the acoustic particle velocity (called also acoustic velocity). and acoustic pressure (Ia=p v) and represents a stream of acoustic energy flowing in the field. This vector parameter of acoustic wave can be measured with special sound intensity probe and can be easily shown in a graphical form.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
