方案下载应用领域 | 交通 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The far wake trajectory of the tumbling tip vortex effect of a reduced-scale, 1 m diame- ter, four-bladed rotor during hover is studied using vortex methods combined with a center of mass analysis approach. Measurements of all three components of the velocity field are acquired using a stereo PIV system synchronized to capture up to 800 wake age of the vortex with 10 offsets during hover conditions. The nominal operating condition of the rotor is at a rotational speed of 1520RPM, corresponding to Rec = 248,000 with a chord length of 58.5mm. The rotor was operated with a pitch of 7.2± 0.5 and a CT / of 0.029. The far wake vortex tumbling phenomenon is captured and described. It is shown that tip vortices from two blades tumble through approximately 180 of rotation before they coalesce. It is seen that the parent vortices are stronger than the daughter vortex, but due to vortex stretching the daughter vortex has a smaller radius with greater swirl strength. An accurate characterization and prediction of the trajectory of the far wake vortex tum- bling can enhance the ability to predict and alleviate the resuspension of particles during brownout as well as provide a database for far wake validation of CFD codes.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
