方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Turbulence of the round jet has been assessed using invariants of the velocity gradient tensor. Experimental data, obtained using Tomographic Particle Image Velocimetry (Tomo-PIV), using four PCO-4000 cameras with 11 megapixel resolution, is presented for a seeded free air jet, operating in the turbulent regime and the Re number based on the diameter of the nozzle is 10000. Using the acquired 3-D velocity fields, the local statistical and geometrical structure of three-dimensional turbulent flow can be described by properties of the velocity gradient tensor. The invariants of the velocity gradient (R and Q), rate-of-strain ( Rs andQs ), and rate-of-rotation (Qw ) tensors are analyzed across the turbulent expanding regions at different distances from the nozzle outlet. More specifically, the JPDF of invariants is computed, which allows a detailed statistical characterization of the dynamics, geometry and topology of the flow during the entrainment process. It should be noted that the results obtained are indicative of the preliminary work in this area.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
