方案下载应用领域 | 电子/电气 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
全场测试。测试对象为辉光放电中的等离子体。和理论计算模拟相对比。对于电子设备散热,器件热传导规律的认识有借鉴和参照意义。
The increasing complexity of electronic devices and components challenges
conventional cooling techniques. For continued development in the electronics field,innovative cooling techniques are required. This thesis examines heat transfer enhancement of a heated plate experiencing low-velocity forced convection. A wire-torod corona discharge electrode configuration was used to generate a counter-flow ionic wind so as to direct the bulk gas flow in such a manner as to induce hot spot cooling.
Particle image velocimetry (PIV) studies were conducted to profile the interaction
between the bulk flow and counter-flow ionic wind and show how the hydrodynamic
interactions result in a downward flow towards the heated surface and characteristic recirculation zones. This impingement-like effect enhanced the convection cooling of the heated plate, reducing the temperature by as much as 5 K. Convection coefficient was enhanced by up to 36% in the heat transfer experiments. In the PIV experiments,seeding particles were used to obtain the fluid flow profile. As corona discharge creates a charged environment, seeding particles may get charged, and this may result in deviation from fluid flow due to Coulombic forces on the particles. To ensure the fidelity of the PIV results in these experiments, a simplified particle tracking analysis was
conducted, solving the modified Basset-Boussinesq-Oseen (BBO) equation for particle
motion and including charging and electric field effects to simulate the effects of corona discharge. The results obtained from these simulations were used to affirm the validity of the PIV results.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
