方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The adsorption and interfacial rheological properties of proteins are of particular interest in many technological applications, such as foam and emulsion formation and stabilisation. Interfacial rheological parameters are useful tools to understand the structure formation in adsorption layers at liquid interfaces. Amphiphilic bio-polymers, such as proteins, adsorb spontaneously at interfaces. The formation of a protein adsorption layer at the air/water or oil/water interface involves adsorption followed by conformational changes. Combined studies of the adsorption and rheological behaviour of protein adsorption layers are also useful to elucidate the intermolecular interaction. During the adsorption process at an interface, protein molecules tend to unfold. The extent of unfolding of proteins depends on the surface concentration. A torsion pendulum rheometer is used to measure the interfacial shear rheological properties. This method can be applied to the water/air and water/oil interfaces. To interpret the complex properties of the adsorption layer of ß-lactoglobulin and ß-casein additional data from measurements of dynamic interfacial tension obtained by the pendent drop technique (ADSA) and adsorption layer thickness obtained from ellipsometry are used.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
