方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Multiple concentrated vortices are often produced in the wake of lifting surfaces and downstream of pumps, turbines, and propulsors. The roll-up of multiple vortex strands is a common feature of these flows. In this study, we are examining the interaction of two vortices of variable strength and relative rotation (e.g. co-rotating or counter-rotating). A pair of equal-strength co-rotating vortices will merge to form a single vortex. However, as the relative strength of the vortices is decreased, the weaker vortex can wrap around the stronger vortex, causing the weaker vortex to be stretched. This stretching process can lead to cavitation inception. In the present work, we will examine this inception process.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
