方案下载应用领域 | 交通 |
检测样本 | 船舶 |
检测项目 | |
参考标准 | 暂无 |
This paper presents preliminary results of research being conducted at MIT on the dynamics of an azimuthing podded propulsor, with emphasis on the application to nonlinear vehicle maneuvering dynamics. The paper focuses on the experimental investigation of propulsor-induced maneuvering forces and moments, as well as characterization and documentation of the vortex wake. A test program of quasi-steady and unsteady/dynamic tests on an azimuthing podded propulsor unit has been carried out in the MIT ship model towing tank. Forces and motor current were measured for subsequent implementation of a multi-parameter dynamic model of an azimuthing propulsor within nonlinear vehicle maneuvering simulations. Additional testing was conducted with the azimuthing propulsor installed in a surface vehicle attached to a Planar Motion Mechanism (PMM), where quasi-steady forces and moments were measured. Parameterized results, as well as notable maneuvering force effects and visualizations of the wake are presented. Parametric results clearly illustrate unique characteristics of vectored-propulsion, including significant increase in vectored thrust and strong “destabilizing” thrust and normal force with propulsor azimuth, plus other important related effects. Limited results of wake flow visualization, using Particle Image Velocimetry (PIV), are also presented.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
