关于油/水, 空气/水界面的过渡态研究
2008/05/03   下载量: 45
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
Insoluble monolayers at the air-water interface are exposed to a gas phase containing organic hydrocarbons. The hydrocarbons are partly incorporated within the monolayer which leads to changes in orientational order and the formation of new phases of different morphology. The transition state resembles features of the air-water and oil-water interface and the control of the hydrocarbon partial pressure allows continous tuning between both interfaces. The phospholipid D,L-R-dipalmitoylphosphatidylethanolamine,DPPE, and an esterdiol hexadecanoic acid, 2,3-dihydroxypropyl ester, ESD-16, are used as amphiphiles, and pentane, n-hexane, cyclohexane, 2,2-dimethylbutane, n-heptane, n-decane, and n-dodecane are used as hydrocarbons. Both amphiphiles differ in their headgroup size. In DPPE the aliphatic tail determines the packing within the monolayer, but in the case of ESD-16 it is the headgroups.The structural changes are monitiored by surface pressure-area (ð,A) isotherms and imaging ellipsometry.The influence of the chemical nature of the hydrocarbon and the effect of the partial pressure of the hydrocarbon on the monolayer structure are assessed.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 Langmuir–Blodgett Films
文献贡献者
相关方案
当前位置: 欧兰科技 方案 关于油/水, 空气/水界面的过渡态研究
