方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Research on laser-liquid interaction and its induced fluid flows, as well as microbubbles, is important in many applications, such as laser ophthalmic microsurgery, manufacturing and repairing of micro-electronic-mechanical devices, laser deposition of thin liquid film to a specific location in micro system, etc. This work was focused on the interaction mechanisms of a laser pulse with distilled/degassed water as well as the characteristics of the microbubbles. Microbubbles and optohydrodynamic flows induced by a Nd:YAG pulse laser (New Wave Research) were studied. A recently improved PIV and PDA system were used to analyze the bubble dynamics and fluid flow quantitatively. Two CCD cameras were used to capture the images of microbubbles and visualize the laser induced Optohydrodynamic flows. The experimental results show that a bright fluid beam (density flow) with duration less than 127μs is produced by a focused laser pulse while an explosive cavitation just around the focus point is also occurred. Immediately following the fluid beam and the explosive cavitation, two new fluid regions which may be formed with the superheated dense fluid were found. One of them is just under the fluid beam due to the optical pressure while the other one is around the explosion area due to the force caused by the explosive cavitation. As shown in Figure 1, Single and multi microbubbles were generated immediately after the cavitation explosion when the nucleation conditions were satisfied. In addition, the characteristics, such as bubble velocities and diameters, were measured by a recently improved phase-Doppler anemometry (PDA). These results will help to have a better understanding of the mechanisms of laser-induced optohydrodynamic flows and bubbles related phenomena, which is crucial to numerical modeling.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
