方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 理化分析>尾气检测 |
参考标准 | 暂无 |
Growing environmental concerns, such as global warming due to the emission of the greenhouse gas CO2 by automotive power plants, lead to the need for cleaner and fuel saving combustion systems. Direct injection combustion systems applied to the spark ignited engine might be a way to improve the efficiency particularly by reducing pumping and heat losses during part load while maintaining the advantages of high power density and engine speeds during high loads [Zhao, Lai et al., 1999]. Initially, wall guided combustion systems were pursued, but high hydrocarbon and soot emissions led to the investigation of spray guided systems. Here a higher degree of stratification is possible, which yields improved emissions [Drake, Fansler et al., 2004; Honda, Kawamoto et al., 2004]. Nonetheless, due to high oxygen availability and locally rich mixture, the nitric oxide formation is comparably high. This is detrimental as the widely employed exhaust aftertreatment by a three way catalytic converter is inefficient for overall lean mixtures. NO storage catalytic converters are widely employed, but require rich exhaust gas to reduce the stored NO. This is generated by operating the engine homogeneous-rich for a brief period of time, which of course comes with a fuel consumption penalty [Tamura, Kikuchi et al., 2001; Krebs, Pott et al., 2002]. A reduction of in-cylinder nitric oxide is desirable to minimize the number of regeneration cycles. Hence the understanding of in-cylinder NO formation is important, so that the necessary scientific background for improvement of the combustion system is provided. An assessment of the NO formation process inside the engine exclusively by drawing conclusions from engine out emissions is difficult, because of the highly inhomogeneous nature of the stratified charge combustion process. Also, due to high cyclic variability cycle resolved measurements are desirable, which conventional emissions analyzers are not capable of.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
