方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Practical diagnostic strategies for detection of temperature and nitric oxide (NO) in high pressure (p<60bar) combustion systems using Laser-Induced-Fluorescence (LIF) of nitric oxide are investigated. NO-LIF, when applied to elevated pressures, suffers from a decrease of signal due to pressure broadening and attenuation of the propagating laser beam/fluorescence signals. In addition, overlapping of neighboring excitation lines and interference from LIF of other species (mainly O2 and CO2) can significantly influence the overall signal. The main purpose of this study is to investigate NO-LIF strategies which minimize the impact of these complications or allow for correction of their effects. A comprehensive study of NO-LIF in a laboratory high-pressure flame was carried out for various flame stoichiometries, pressures and excitation wavelengths to develop optimized excitation and detection strategies for high-pressure applications. Four main issues are addressed in this study. First, optimized excitation strategies are investigated for high-pressure applications in the A2Σ+−X2Π (0,0), (0,1) and (0,2) bands of NO. Second, CO2-LIF is identified as a major source of interference in the detection of NO-LIF in high-pressure combustion systems involving hydrocarbon chemistry. Third, an accurate multi-line thermometry technique for steady, high-pressure flames is proposed by fitting wavelength-scanned NO-LIF with computational simulations. Finally, measurements optimizing the detection strategies of 2-D NO-LIF imaging in high-pressure flames are reported. The discussion and demonstrations reported in this study provide a practical guideline for application of instantaneous 1-D or 2-D NO-LIF imaging in high-pressure combustion systems.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
