方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Here we report a detailed study on spectroscopy, structure and dynamics of water molecules at air/water interface, investigated with Sum Frequency Generation Vibrational Spectroscopy (SFGVS). Quantitative polarization and experimental configuration analysis of the SFG data in different polarizations with four sets of experimental configurations can shed new lights on our present understanding of the air/water interface. Firstly, we concluded that the motion of the interfacial water molecules can only be in a limited angular range, instead rapidly varying over a broad angular range in the vibrational relaxation time suggested previously. Secondly, because different vibrational modes of different molecular species at the interface has different symmetry properties, polarization and symmetry analysis of the SFG-VS spectral features can help assignment of the SFG-VS spectra peaks to different interfacial species. These analysis concluded that the narrow 3693cm−1 and broad 3550cm−1 peaks belong to C∞v symmetry, while the broad 3250cm−1 and 3450cm−1 peaks belong to the symmetric stretching modes with C2v symmetry. Thus, the 3693cm−1 peak is assigned to the free OH, the 3550cm−1 peak is assigned to the single hydrogen bonded OH stretching mode, and the 3250cm−1 and 3450cm−1 peaks are assigned to interfacial water molecules as two hydrogen donors for hydrogen bonding (with C2v symmetry), respectively. Thirdly, analysis of the SFG-VS spectra concluded that the singly hydrogen bonded water molecules at the air/water interface have their dipole vector direct almost parallel to the interface, and is with a very narrow orientational distribution. The doubly hydrogen bond donor water molecules have their dipole vector point away from the liquid phase.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
