乙二醇蒸气在阿尔法三氧化二铝和不定形二氧化硅表面的吸附过程研究:观察分子取向和作为吸附点的表面羟基组团
2008/04/26   下载量: 168
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
Vapor adsorption is an important process influencing the migration and the fates of many organic pollutants in the environment. In this study, adsorption of ethylene glycol (EG) vapor onto single crystal R-Al2O3 (0001) and fused SiO2 (amorphous) surfaces was studied with sum frequency generation spectroscopy, a well-suited surface specific technique for probing interfacial phenomena at the molecular scale. Air-aqueous EG solutions were also investigated to compare to the adsorption at the air-solid interface in the presence of water vapor. The gauche conformer of EG molecules dominates the air-aqueous EG solution interface, and EG molecules act as hydrogen acceptors at the air-liquid interface. Water and surface hydrophilic/ hydrophobic properties play important roles for the adsorption of EG onto silica and alumina surfaces. The adsorbed EG molecules interact in different ways at the two different oxide surfaces. EG molecules weakly physisorb onto the R-Al2O3 (0001) surface by forming relatively weak hydrogen bonds with surface water molecules. On the silica surface, the suppression of the silanol OH stretching peak indicates that EG molecules form hydrogen bonds with silanol OH groups. Introduction
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 用和频光谱(SFG)方法进行羧酸盐在萤石和水界面吸附过程的在线研究
文献贡献者
相关方案
当前位置: 欧兰科技 方案 乙二醇蒸气在阿尔法三氧化二铝和不定形二氧化硅表面的吸附过程研究:观察分子取向和作为吸附点的表面羟基组团
