用和频发生(SFG)振动光谱学方法探测紫外光和等离子体表面改性聚二甲基硅氧烷的动力学过程研究
2008/05/10   下载量: 120
方案下载
应用领域 石油/化工
检测样本 其他
检测项目
参考标准 暂无
In numerous applications in microfluidics, cell growth, soft lithography, and molecular imprinting, the surface of poly(dimethylsiloxane) (PDMS) is modified from a hydrophobic methyl-terminated surface to a hydrophilic hydroxylterminated surface. In this study, we investigated molecular structural and orientational changes at the PDMS-air interface in response to three commonly used surface modification processes: exposure to long-wavelength ultraviolet light (UV), exposure to short-wavelength UV that generates ozone (UVO), and exposure to oxygen plasma (OP). The surfaces of two PDMS compositions (10:1 and 4:1 of base polymer/curing agent) were probed during modification, using monolayer-sensitive IR + visible sum frequency generation (SFG) vibrational spectroscopy, with two different polarization combinations. During PDMS surface modification, the peak intensities of CH3 side groups and CH2 cross-link groups decreased, while peak intensities of Si-OH groups increased. There was no significant change in the average orientation of the CH3 groups on the PDMS surface during modification. The concentration of CH3 groups on the surface decreased exponentially with time, for all three UV, UVO, and OP modification processes, with first order kinetics and time constants of approximately 160, 66, and 0.3 min, respectively. At steady state, residual CH3 groups were detected at the PDMS surface for UV and UVO treatments; however, there were negligible CH3 groups detected after OP modification.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 金/溶液界面处十八烷基硫醇单分子层膜构象有序性研究:采用内部反射式和频发生(SFG)方法
文献贡献者
相关方案
当前位置: 欧兰科技 方案 用和频发生(SFG)振动光谱学方法探测紫外光和等离子体表面改性聚二甲基硅氧烷的动力学过程研究
