方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Stratified exchange flows driven by a density difference are found in many natural water bodies and in the atmosphere. A typical case in nature is the strait of Gibraltar, where the water of the Mediterranean Sea flows under the less saline water of the Atlantic Ocean. At the interface between the layers shear is responsible for instabilities (Kelvin-Helmholtz), which results in turbulent mixing and entrainment. Gaining deeper understanding of these processes is the main motivation for this thesis. An experimental study into the development of a mixing layer of a two layer stratified exchange flow is performed and an LIF measurement system was used to obtain the concentration fields. The main objectives of this study were to calibrate and understand the experimental set-up and to investigate the influence of four different parameters on the development of the mixing layer. The calibration of the experimental set-up has led to a simple calibration procedure, which was applied with success. To study the development of the mixing layer the influence of four different parameters was analyzed namely: the buoyant acceleration, the bottom friction, the water depth and the sill slope. After careful analysis of the experimental results it was observed that fluid from the upper layer was entrained into the lower layer in all the experiments. Analysis of the dye visualization showed that the large-scale structures, the Kelvin-Helmholtz instabilities, are mainly responsible for the mixing and entrainment. The overall conclusion was that the variation of geometric condition on the development of the mixing layer has a much stronger influence than the variation of the hydraulic conditions. An enhanced bottom friction affected the Kelvin-Helmholtz instabilities but the mechanism is not completely understood by the author.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
