方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The wake of a circular cylinder at Re = 2700 is investigated by means of Tomographic PIV (Tomo-PIV), a recently developed three-dimensional velocimetry technique. The paper presents the principles of Tomo-PIV and discusses in details the implementation of the technique to the experimental conditions. With a measurement volume of approximately 40x40x10 mm2 two configurations are chosen in order to describe both the 2D wake features and the span wise organization of secondary rollers dominating the 3D flow organization. The present data allow to directly evaluate the measurement error imposing mass conservation inside the volume (viz. solenoidal velocity field). The visualization of the wake instantaneous structure is obtained by means of vorticity vector magnitude iso-surfaces, or decomposing the vorticity in the span wise and stream-wise(normal)/bi-normal component, which return the separate contribution of the Kármán rollers and the interconnecting structures between them respectively. The properties of the secondary rollers are given in terms of span wise wavelength, peak vorticity, vorticity stretching and their size and shape. A value of the span wise wavelength λ z/D = 1.2 is recurring and the rollers organization into pairs is found to be similar to the instability Mode B occurring in lower Reynolds number wakes investigated with previous studies.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
