方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Two-phase annular flow is commonly used in both commercial and industrial heat transfer; however, we do not yet possess a thorough understanding of the nature of the fluid. Most analytical annular two-phase models are based on a relationship between the liquid film thickness, liquid film mass flux, and the axial pressure gradient or interfacial shear stress. The film thickness calculated from these models can then be utilized to determine the heat transfer coefficient of the flow. Although they are specific to certain flow regimes and fluids, empirical models remain more accurate than these analytical models. The key to understanding these flows lies with the liquid film. Therefore, to better understand the pressure drop and heat transfer of annular two-phase flow, this study involves the development of local, liquid velocity measurement techniques and their application to horizontal, wavy-annular two-phase flow. Two techniques, Bubble Streak Tracking (BST) and Thin Film Particle Image Velocimetry (TFPIV), have been developed in this study. Utilizing naturally occurring bubbles within the liquid film, the BST technique determines the liquid velocity by measuring reflected light streaks from the bubbles. A three-colored LED array creates directionally unambiguous streaks, while a strobe illuminates interfacial features that affect the liquid velocity. The TFPIV technique applies a typical micro-PIV system to a macroscopic flow with the addition of a non-trivial image processing algorithm. This algorithm successfully overcomes the image noise that occurs when applying PIV to a two-phase, thin film. Although difficulties arise when processing the BST data, the results of the BST and TFPIV methods are comparable, making BST an economical alternative to TFPIV for calculating liquid film velocities.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
