方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Pulsed jets have found a wide variety of applications in the area of flow control during the recent years. The goal of the current study is to identify the flow field and mixing characteristics associated with an incompressible circular jet through a flexible nozzle. The flow was self-excited over a range of conditions and produced a pulsatile flow. The frequency of excitation was found to be between 150-175Hz. Phase-locked and time averaged 2D Particle image Velocimetry (PIV) was used to study the dynamic characteristics of the flow. The flow field shows that two different modes could be excited depending on nozzle characteristic. The flapping mode was associated with alternate shedding of vortices. This introduces strong steering of the jet to one side or the other. Turbulence, Jet spread and entrainment characteristics were far more superior to the non-flapping or a pulsed jet. The second mode which was a non-flapping mode is associated with the formation of a counter rotating vortex pair. The turbulence associated with both these modes was convected along with the vortical structure in the flow. The jet vortices formed by the self-excited flow were not just convected by the flow, but these determined the flow field and mixing characteristics of the jet.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
