方案下载应用领域 | 地矿 |
检测样本 | 非金属矿产 |
检测项目 | |
参考标准 | 暂无 |
Large scale digital particle image velocimetry (PIV) and laser speckle velocimetry (LSV) are applied to landslide generated impulse waves. The challenges posed to the measurement techniques in an extremely unsteady three phase flow consisting of granular matter, air and water are considered. Areas of interest up to 0.8 m by 0.8 m are investigated in the impulse wave generation zone. The complex flow phenomena present in the first stage of impulse wave initiation are: High speed granular slide impact, impulse flux transfer, flow separation and reattachement, cavity formation and collapse, slide deformation and penetration into fluid. During this first stage the three phases are separated along sharp interfaces changing significantly within time and space. A combined analysis method for PIV in water flow and LSV on the corona of the landslide surface is presented. Digital masking techniques are applied to distinguish between phases thereafter allowing phase separated image processing. The combination of PIV and LSV reveals insight into the impulse transfer mechanism. Applicability of PIV at large scale as well as to flows with large velocity gradients due to the presence of a strong shock are highlighted. An introductory vector-field obtained by means of PIV is shown in Fig. 1 with flow reattachement and characteristic saddle point above slide shoulder. Subsequent wave generation stages with granulate detrainment, bubble break up and massive phase mixing are not considered here.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
