方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The analysis of the flow field inside hydraulic valves has become in the last few years a very important issue to be addressed in order to optimize the spool shapes and to obtain the desired flow metering characteristics. The Fluid-Power research unit of the Polytechnic of Bari realized many works dealing with the Computational Fluid Dynamics (CFD) analysis of directional control valves. Experimental measurements concerning discharged flow rate and needed driving force values have been performed in order to validate the numerical results, but the validation of CFD results has been limited, in the past, only to the global fluid dynamic response of the valve and not to the local flow conditions. In order to provide the flow field inside the valve through PIV (Particle Image Velocimetry) measurements, a valve model, equipped with a great optical access, has been realized. The scaled model has been realized according to the fluid dynamic similarity laws in order to use a fluid different from the oil (water) and to increase the dimensions of the valve. In particular, the realized model has a circumferential development useful to acquire important data about the circumferential flows and their effects on the global flow rate crossing the valve. The experimental results show that the velocity profiles in the metering sections are strongly influenced by the three-dimensional effects of the flow, confirming the results obtained numerically in previous works.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
