方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
A coaxial jet was actively controlled by a MEMS-fabricated micro flap actuator nozzle. The effect of different control modes on secondary azimuthal instabilities and the evolution of streamwise vortices were investigated by applying stereoscopic PIV to the cross-stream plane of the jet. Forcing with non-symmetric modes, in particular the least-stable helical mode, accelerates the evolution of the streamwise vortices through the enhancement of azimuthal instabilities. Although forcing is applied to the outer shear layer of the outer jet, the control effect is most pronounced in the inner shear layer of the inner jet. Unlike in the natural jet, streamwise vortices appear in the inner shear layer of the controlled jet. For forcing with the fundamental axisymmetric mode, a Strouhal number of the order of unity maximise the azimuthal instabilities and hence the counts of the streamwise vortices. The present result is in accordance with our previous experimental findings in the longitudinal plane, where the evolution of the primary vortices and mixing between the inner and the outer jets were examined through 2D-PIV and PLIF (Kurimoto et al., 2004, Active control of coaxial jet mixing with arrayed micro actuators. Transactions of the Japanese Society of Mechanical Engineers, pp. 31–38.) This emphasises the connection between primary and streamwise vortices and their significance in the mixing enhancement process. It is also found that the azimuthal wavelength under the present control scheme is almost the same as that of the natural jet and independent of the streamwise position.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
