方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
An experimental study of the interaction of a planar diffusion flame with a line vortex is presented. A planar diffusion flame is established between two coflowing, equal velocity streams of acetylene diluted with nitrogen and air. A line vortex is generated on demand by momentarily pulsing one of the flow streams by way of electromagnetic actuation of a piston in the flow apparatus. The flame–vortex interactions are diagnosed by planar laser-induced incandescence for soot yield and by particle image velocimetry for vortex flow characterization. The results show that soot formation and distribution are influenced by the reactant streams from which vortices are initiated. The vortices interacting with the flame from the air side produce more soot and soot is distributed in and around the vortex core in diffuse layers. In contrast, topography of soot in vortices interacting from the fuel side is such that soot is confined to thinner layers around the vortex core which does not contain any soot. The flame curvature is found to influence the local soot production with the flame regions convex to the fuel side containing more soot locally. It is also found that the overall soot yield is less sensitive to the vortex strength and is of lower magnitude when vortex is spun from the fuel side. The knowledge of this type of asymmetry in soot yield in flame–vortex interactions is useful for combustion engineering and design of practical devices.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
