微观水滴表面张力降低的明显证据
2016/09/18   下载量: 7
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
The ability of airborne particles to take up water may be enhanced by surface-active components, but the importance of this effect is controversial because direct measurement of the surface tension of microscopic droplets has not been possible. Here we infer droplet surface tension from water uptake measurements of mixed organic-inorganic particles at relative humidities just below saturation (99.3–99.9%). The surface tension of droplets formed on particles composed of NaCl and a-pinene ozonolysis products was reduced by 50–75%, but only when enough organic material was present to form a film on the droplet surface at least 0.8 nm thick. This study suggests that if atmospheric particles are predominantly (?80%) composed of surface-active material, their influence on cloud properties and thus climate could be enhanced, and their atmospheric lifetimes could be reduced. Citation: Ruehl, C. R., P. Y. Chuang, A. Nenes, C. D. Cappa, K. R. Kolesar, and A. H. Goldstein (2012), Strong evidence of surface tension reduction in microscopic aqueous droplets,
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 湿法烟气脱硫(WFGD)喷雾塔的分析优化
文献贡献者
相关方案
当前位置: 欧兰科技 方案 微观水滴表面张力降低的明显证据
