方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The mass balance of orchard air-blast sprayers has historically been assessed using an array of samplers to capture airborne particles. However, these methods only provide an idea of flux with no other information which is pertinent to understand the movement of droplets and their potential to drift. While droplet analysis for agricultural sprayers has always been conducted in a laboratory setting with the use of laser devices, a new phase Doppler approach is being explored to assess droplet spectra, velocity, and flux in outdoor field conditions. Therefore it is the objective of this study to develop a methodology and the potential limitations for using a phase Doppler system while in a laboratory setting. Due to the expected variability of field conditions as well as the turbulence of orchard sprayers, a computational approach was sought to assess flux from a single scan of a conical spray plume's diameter. Using a constant scanning speed of 0.0079 m/s, a disc core (D1/DC33) hollow cone nozzle was examined at 310, 410, and 520 kPa pressure at five different heights (10, 20, 30, 40, and 50 cm). Computational flux was then compared to the actual flow rate, finding a 3.3% average error with a range of 16.9% and 4.7% illustrating a small underestimation of mass with the phase Doppler which was related to distance and droplet frequency. Further, comparisons were also assessed including pattern/symmetry, droplet spectra, velocity, and the overall number of samples. The proposed methodology indicates potential for the use of phase Doppler technology for in situ measurements of spray equipment using a conical-type spray nozzle, such as that of the orchard air-blast sprayer.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
