落到倾斜箔片上的液体薄膜流动的时间空间分辨热传导过程的实验研究
2016/10/17   下载量: 1
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 暂无
This paper describes the development of an experimental technique that combines simultaneous planar laser-induced fluorescence (PLIF) and infrared (IR) thermography imaging, and its application to the measurement of unsteady and conjugate heat-transfer in harmonically forced, thin liquid-film flows falling under the action of gravity over an inclined electrically heated-foil substrate. Quantitative, spatiotemporally resolved and simultaneously conducted measurements are reported of the film thickness, film free-surface temperature, solid–liquid substrate interface temperature, and local/instantaneous heat flux exchanged with the heated substrate. Based on this information, local and instantaneous heat-transfer coefficients (HTCs) are recovered. Results concerning the local and instantaneous HTC and how this is correlated with the local and instantaneous film thickness suggest considerable heat-transfer enhancement relative to steady-flow predictions in the thinner film regions. This behaviour is attributed to a number of unsteady/mixing transport processes within the wavy films that are not captured by laminar, steady-flow analysis. The Nusselt number Nu increases with the Reynolds number Re; at low Re values the mean Nu number corresponds to 2.5, in agreement with the steady-flow theory, while at higher Re, both the Nu number and the HTC exhibit significantly enhanced values. Evidence that the HTC becomes decoupled from the film thickness for the upper range of observed film thicknesses is also presented. Finally, smaller film thickness fluctuation intensities were associated with higher HTC fluctuation intensities, while the amplitude of the wall temperature fluctuations was almost proportional to the amplitude of the HTC fluctuations.
方案下载
配置单
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 游动的未成熟海胆幼虫的个体发育变化和湍流中的取向
文献贡献者
相关方案
当前位置: 欧兰科技 方案 落到倾斜箔片上的液体薄膜流动的时间空间分辨热传导过程的实验研究
