方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
Injection processing of composite materials most often includes infiltration of a thermoset resin into a multi-scale porous fabric. Controlling the fluid flow within the multiscale fabric is essential for the quality of the final composite material, since the transport of fluid between regions with different scales plays an important role in phenomena such as void formation and filtration of particle doped resins. In this work, the transient flow behaviour in dual scale porous media is investigated with Micro Particle Image Velocimetry in order to enhance the knowledge and control of the processing of multi-scale composites so that their quality can be improved. Experiments show that the fluid transport between the two scales can be controlled by the injection velocity. Validation of the measured velocity fields furthermore shows excellent agreement with theory.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
