方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 其他>其他 |
参考标准 | 暂无 |
Modern spark-ignited internal combustion engines have intake ports designed to introduce high levels of so-called “tumble” charge motion. Correspondingly high shear rates can lead to high fluctuations and turbulence within the combustion chamber. A suitable test case to characterize the intake flow is a steady-state flow bench. Although routinely used in the engine development process to determine the global discharge coefficients, only a few detailed numerical and experimental studies use this test case to analyze the flow in the vicinity of the valve with high spatial and temporal resolution. In this paper, we combined highly resolved two-dimensional, two-component Particle Image Velocimetry (PIV) measurements and numerical simulations using a Detached-Eddy Simulation (DES) model to characterize engine-relevant flow features on a flow bench. The spatial resolution of numerical simulations on two different grids is assessed and compared to that of the PIV measurement. The results of simulations and experiment are then compared in terms of their mean and fluctuation velocity fields and the jet orientation. A detailed study of the area around the valve seats investigates the validity of wall functions in this region. Finally, we examine structures induced by vortex-shedding at the valve stem and if they are transported into the combustion chamber.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
