方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
The present study deals with the ow eld in the circular cross section of a cylindrical vessel induced by a rotationally reciprocating impeller, rotating back and forth with gradual change in rotational speed. A periodically stable velocity eld was measured by PIV and also simulated by CFD. It was revealed that the velocity eld near the liquid free surface is basically 2-dimensional, except for the acceleration period at Re43, and agrees well with 2-dimensional CFD simulation, except for the development process of 3-dimensional tip vortices at Re43. The separation behavior of the vortices originally generated at the impeller tip changed with increasing Reynolds number. No separation was observed at a lower Reynolds number, while the separated vortices turn into 3-dimensional potential vortices and remain as 2-dimensional vortices at the next impeller counterturn at higher Reynolds numbers. The uctuation of each velocity component was remarkably small, suggesting that the ow eld even at the highest Reynolds number was still laminar. It is found that eective transportation of energy from the impeller to 3-dimensional potential vortex is related to a large and constant power number, which is reported in our recent publication.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
