方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司的PIV系统。激光器能量为双脉冲400毫焦。对7马赫高超音速风洞中的15度-45度双斜面流场进行了测量。获得了流场中激波的空间分布的详细信息。
A Mach 7 flow over a 15o-45o double ramp was investigated by means of PIV and high-speed
schlieren imaging. The flow field features an Edney type V shock-shock interaction. Downstream of
the interaction a wall-jet is observed that is the result of the momentum difference in the flow
passing through the curved shock or through the series of oblique shocks in the interaction. Vortical
structures were observed in the wall-jet shear layer, that were generated at a frequency of 40 kHz.
Finally, the unsteadiness of the shock structure was studied and it was found that the leading edge
shock was stationary while both the separation and curved shocks showed appreciable motion. The
movement of these two shocks was found to be uncorrelated.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
