活塞发动机湍流研究:统计理论预测量和瞬态湍流的耦合
2017/06/23   下载量: 4
方案下载
应用领域 汽车及零部件
检测样本 汽车电子电器
检测项目 其他>其他
参考标准 暂无
利用德国LaVision公司的层析粒子成像测速(Tomo-PIV)和时间分辨粒子成像测速(TR-PIV)系统,测量汽车活塞发动机内部瞬态湍流场并和理论分析预测结果进行比对。
方案下载
配置单
方案详情
Planar particle image velocimetry (PIV) and tomographic PIV (TPIV) measurements
are utilized to analyze turbulent statistical theory quantities and the instantaneous
turbulence within a single-cylinder optical engine. Measurements are performed
during the intake and mid-compression stroke at 800 and 1500 RPM. TPIV
facilitates the evaluation of spatially-resolved Reynolds stress tensor (RST) distributions,
anisotropic Reynolds stress invariants, and instantaneous turbulent vortical
structures. The RST analysis describes distributions of individual velocity fluctuation
components that arise from unsteady turbulent flow behavior as well as cycle-to-cycle
variability (CCV). A conditional analysis, for which instantaneous PIV images are
sampled by their tumble center location, reveals that CCV and turbulence have similar
contributions to RST distributions at the mean tumble center, but turbulence
is dominant in regions peripheral to the tumble center. Analysis of the anisotropic
Reynolds stress invariants reveals the spatial distribution of axisymmetric expansion,
axisymmetric contraction, and 3D isotropy within the cylinder. Findings indicate
that the mid-compression flow exhibits a higher tendency toward 3D isotropy than
the intake flow. A novel post-processing algorithm is utilized to classify the geometry
of instantaneous turbulent vortical structures and evaluate their frequency of occurrence
within the cylinder. Findings are coupled with statistical theory quantities to
provide a comprehensive understanding of the distribution of turbulent velocity components,
the distribution of anisotropic states of turbulence, and compare the turbulent
vortical flow distribution that is theoretically expected to what is experimentally
observed. The analyses reveal requisites of important turbulent flow quantities and
discern their sensitivity to the local flow topography and engine operation.
上一篇 在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
下一篇 3D光定位能在白色油漆中实现吗?
文献贡献者
相关方案
当前位置: 欧兰科技 方案 活塞发动机湍流研究:统计理论预测量和瞬态湍流的耦合
