方案下载应用领域 | 能源/新能源 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用当前世界上唯一商品化的德国LaVision公司的时间分辨高速激光诱导荧光测试系统和时间分辨粒子成像测速系统,对旋流燃烧器中旋进涡核(PVC)的形成和火焰诱导抑制进行了实验和线性稳定性的研究分析。
The precessing vortex core (PVC) is a coherent flow structure that is often encountered
in swirling flows in gas turbine (GT) combustors. In some swirl combustors,
it has been observed that a PVC is present under non-reacting conditions but disappears
in the corresponding reacting cases. Since numerous studies have shown
that a PVC has strong effects on the flame stabilization, it is desirable to understand
the formation and suppression of PVCs in GT combustors. The present work
experimentally studies the flow field in a GT model combustor at atmospheric
pressure. Whereas all non-reacting conditions and detached M-shaped flames exhibit
a PVC, the PVC is suppressed for attached V-shaped flames. A local linear
stability analysis is then applied to the measured time-averaged velocity and density
fields. For the cases where a PVC appeared in the experiment, the analysis
shows a global hydrodynamic instability that manifests in a single-helical mode
with its wavemaker located at the combustor inlet. The frequency of the global
mode is in excellent agreement with the measured oscillation frequency and the
growth rate is approximately zero, indicating the marginally stable limit-cycle.
For the attached V-flame without PVC, strong radial density/temperature gradients
are present at the inlet, which are shown to suppress the global instability.
The interplay between the PVC and the flame is further investigated by consid-ering a bi-stable case with intermittent transitions between V- and M-flame. The
flame and flow transients are investigated experimentally via simultaneous highspeed
PIV and OH-PLIF. The experiments reveal a sequence of events wherein
the PVC forms prior to the transition of the flame shape. The results demonstrate
the essential role of the PVC in the flame stabilization, and thereby the importance
of a hydrodynamic stability analysis in the design of a swirl combustor.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
