方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 可靠性能>温度试验 |
参考标准 | 暂无 |
采用LaVision以增强型CCD相机为核心器件构成的PLIF测试系统,根据双线原子激光诱导荧光原理,测量分析发动机内部的准瞬态二维温度场。
Two-dimensional thermometry by the two-line atomic fluorescence method (TLAF) from atomic indium
performed in an internal combustion engine is reported for the first time. The engine was a modified
production engine running on iso-octane fuel. Small quantities of atomized indium were admitted to the
engine chamber by injecting solutions containing InCl3 mixed with iso-octane. Temperatures could be
measured over the entire combustion cycle covering a range from 800 to 2800 K at pressures up to 14
bar. A precision of 14% on single-shot temperature distributions was obtained, a figure that is expected to
be much improved if laser intensity profile normalization is performed on a shot-by-shot basis and not, as
in the present case, on averaged intensity profiles. Advantages of the technique are its sensitivity over a
large temperature range, its insensitivity to collisional quenching processes, the small laser powers required,
and the possibility to use wavelengths at which interferences from native flame species, such as small
hydrocarbons, are low. Limitations are discussed, and comparisons with other techniques are made.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
