方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 热性能>燃烧特性 |
参考标准 | 暂无 |
采用LaVision公司以增强型CCD相机为核心构成的平面激光诱导荧光测试系统(PLIF)对均质混合进气直喷汽油发动机中燃料和空气的混合程进行了测量和研究。
For optimum efficiency, the direct injection (DI) gasoline
engine requires two operating modes to cover the full
load/speed map. For lower loads and speeds, stratified
charge operation can be used, while homogeneous
charge is required for high loads and speeds. This paper
has focused its attention on the latter of these modes,
where the performance is highly dependent on the quality
of the fuel spray, evaporation and the air-fuel mixture
preparation.
Results of quantitative and qualitative Laser Induced
Fluorescence (LIF) measurements are presented,
together with shadow-graph spray imaging, made within
an optically accessed DI gasoline engine. These are
compared with previously acquired air flow
measurements, at various injection timings, and with
engine performance and emissions data obtained in a
fired single cylinder non-optical engine, having an
identical cylinder head and piston crown geometry.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
