方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 暂无 |
采用LaVision公司的增强型CCD相机对火焰喷射对象进行了测量。研究了喷嘴直径对火焰举升长度的影响。
This paper reports on the experimental investigation of the flame lift-off length for five different orifice
diameters (∅0.100, ∅0.130, ∅0.160, ∅0.190, and ∅0.227 mm) of a diesel injector nozzle. The flame lift-off
was determined from the measurement of 308 nm OH chemiluminescence for different fuel injection pressures
using commercial diesel fuel and a Common Rail fuel injection equipment of passenger car size. The fuel
injection pressures were 450, 900, and 1350 bar. The experiments were conducted at air pressures of 30, 50, 70,
and 90 bar and at an air temperature of 750 K in a constant pressure spray chamber. It was observed that the
flame lift-off length increases with increased injection pressure and increased orifice diameter.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
