方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车排放与节能 |
检测项目 | 理化分析>发动机排放试验 |
参考标准 | 暂无 |
采用LaVision公司已图像增强器为核心搭建的平面激光诱导荧光测试系统和喷雾分析系统,定量地研究了丙烷/液化石油气喷雾结构及其和环境压力的关系。
When a gasoline engine is converted to propane (LPG, Autogas) there is usually a reduction in power. This loss can be
mitigated by careful design of the injection system such that the heat required for evaporation of the LPG is drawn from
the intake air and not the intake walls. The air is cooled and densified, resulting in an increase in volumetric efficiency.
To do this effectively requires the injector spray pattern to be known. There are many studies on the structure of
gasoline sprays, but few of LPG sprays.
In this work we have imaged LPG sprays from a gasoline direct injection (GDI) injector, a port fuel injector, and from long
and short pipes usually used to connect a remote LPG metering valve to the injection point in the manifold. Both Mie
and LIF imaging have been used. For the LIF, acetone is added to the LPG. Images were taken in an optically accessed
pressure chamber at pressures from atmospheric to 20 bar and with fuel line pressures from 10 to 80 bar.
The imaging of the pipe-coupled injection system shows that (1) there is significant but not complete evaporation in the
pipe, the amount of evaporation depending on the length and diameter of the pipe, and (2) during its travel down the
pipe the injected pulse of fuel spreads out so that the duration of the LPG pulse at the manifold end is, for 300mm pipes,
five times the original duration at the injector, and even greater for 600mm pipes such that fuel is always emerging from
the pipe. When fuel evaporated in the pipe the latent heat required is taken from the pipe wall and not from the induced
air, where it might usefully cool and densify the air, boosting engine torque. The fuel emerges from the pipe in a narrow
jet. This may be less conducive to good mixing than the broad spray which emerges from the close coupled system
(which has the injection valve mounted directly on the manifold.
The structure of the sprays and the amount of evaporation that occurs before the fuel enters the manifold explains the
observed differences in engine torque and in-cylinder mixture temperature observed with the different systems.
The spray structure of the direct injector is similar with gasoline and LPG. The spray structure is more sensitive to
changes in fuel or chamber pressure than to the type of fuel. The droplet size may vary with fuel type, resulting in a
different spray structure when exposed to the strong in-cylinder air motion of a direct injection engine.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
