方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 热性能>燃烧特性 |
参考标准 | 暂无 |
采用LaVsion公司特色的增强型CCD相机为核心部件,构成平面激光诱导荧光测试系统。利用该系统对火花塞引燃发动机内冷焰组分的传播进行了可视化研究。
The flame propagation in a spark-ignition engine has been studied using
laser-induced fluorescence (LIF) of species formed during the first ignition
stage of hydrocarbon combustion. The detected two-dimensional LIF
images showed the distribution of unburned regions. For the excitation, two
Nd:YAG lasers operating at 355 nm were used for two consecutive
measurements within the same engine cycle with adjustable time separation
between the pulses. Two ICCD cameras that were synchronized to each of
the laser pulses recorded pairs of fluorescence images, i.e. the movement of
the flame front could be tracked. It is well known that formaldehyde is
excited using a wavelength of 355 nm and a spectral signature of this species
was also identified in engine LIF spectra. Programme routines were
developed and used for evaluation of the flame propagation velocity from
the fluorescence images. This paper presents the potential and the
characteristics of the experimental technique as well as the evaluation
procedure. The measurements of cool-flame intermediates have also been
compared with measurements of fuel-tracer as an indicator of unburned
fuel–air mixture. A good agreement between position and shape of the
signal areas was obtained at crank angles where both fluorescence signal
from cool-flame species excited at 355 nm and added 3-pentanone excited at
266 nm could be detected.
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
