方案下载应用领域 | 汽车及零部件 |
检测样本 | 汽车电子电器 |
检测项目 | 理化分析>VOC含量 |
参考标准 | 暂无 |
采用LaVision公司特色的以图像增强器为核心部件构成的平面激光诱导荧光(PLIF)测试系统对甲醛在压缩引燃发动机燃烧过程中的作用进行了研究和分析
Combustion of a premixed-charge by compression
ignition is a promising alternative combustion process
as it allows part load operation with high dilution
rate (air and/or residual gas dilution) while preserving
engine stability. This combustion process attracted
attention on account of its potential for achieving
high efficiency and ultra-low NOx emissions [1, 2, 3,
4]. When using commercial gasoline as fuel, autoignition
of a premixed charge in a four-stroke engine
can be achieved with high compression ratio, inlet air
heating or residual gas trapping. CAI refers to autoignition
combustion obtained with a high proportion
of burned gases trapped in the fresh mixture. In this
work, CAI operation is achieved in an engine with a
compression ratio of 11.6 running with gasoline-type
fuel.
While SI combustion is characterized by flame propagation
and associated fast chemical reactions in a
confined reaction zone, chemiluminescence imaging
studies [5] have shown that the CAI combustion process
could be described as a large reaction zone
resulting from an auto-ignition process which occurs
successively at various in-cylinder locations. The
mechanisms which promote auto-ignition involves
both thermal and chemical effects of the recycled burned
gases. While numerous studies have shown that
the heating effect is predominant [6,7], other investigations
emphasized the active role of chemical species
like CO, H2 and NO [8].
在一个双稳湍流涡旋火焰中,对间歇性动态的时间-频率定位
Particle-laden Taylor-Couette流:高阶转变和径向局部波浪涡旋的证据
7根杆束的流体-结构相互作用:用实验数据对比数值模拟
汽车光学检测系统AIS
PT403型波长可调谐皮秒激光器
ANL系列高能量高重复频率DPSS纳秒激光器
APL4206 系列高能量皮秒激光放大器
UltraFlux FF/FT 5000 高能量可调谐飞秒激光器系统
UltraFlux FT300型波长可调谐飞秒激光器系统
Ekspla 超高功率激光器系统SYLOS 2A
LaVision PTUx 可编程时间控制单元
LaVision 用于粒子成像测速PIV的相机
LaVision StrainMaser 全场应变测试系统组件
LaVision 用于数字图像相关DIC的相机
LaVision StrainMaster 数字图像相关分析软件包
LaVision 标定板
LaVision StrainMaster 形变应变成像测量系统
LaVision StrainMaster DVC 体视全场应变测量系统
